Giriş
The front and rear screens are fused into a single assembly and cannot be replaced individually. This guide will show how to replace the complete assembly.
Neye ihtiyacın var
Heat the screen cover with an iOpener, a heat gun or even a hair dryer to soften the adhesive holding it to the display frame.
Remove the four 3.5mm Phillips screws holding the rear cover in place.
The screen is held onto the display frame with adhesive around the outside edge of the LCD, with a thicker bar of adhesive along the bottom edge as shown.
The vibrator is lightly glued to the display frame. Gently pry it loose, mindful of the wires attaching it to the LCD assembly.
Lift the LCD assembly from the display frame. There will probably be several strands of adhesive you'll need to separate as you pull it apart.
