Ana içeriğe geç
Alcatel IdealXCITE Rear Speaker Replacement
Neye ihtiyacın var
  1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: adım 1, 3 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement, Battery: adım 1, 3 resimden 2. Alcatel IdealXCITE Rear Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Place your finger in the small notch on the left corner of the phone.
    • Use your finger to gently pull up on the back cover where the notch is located.
    • Gently pull up on the back cover, working around the phone.
    • Remove the cover from the phone, and set it aside for later installation.
  2. Alcatel IdealXCITE Rear Speaker Replacement: adım 2, 3 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement: adım 2, 3 resimden 2. Alcatel IdealXCITE Rear Speaker Replacement: adım 2, 3 resimden 3.
    • Place your thumb in the small notch between the battery and the phone.
    • Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
    • Take note of the contacts in the phone and on the battery for reinstallation.
  3. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: adım 3, 2 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement, Antenna: adım 3, 2 resimden 2.
    • Remove the four 4mm PH00 screws.
  4. Alcatel IdealXCITE Rear Speaker Replacement: adım 4, 3 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement: adım 4, 3 resimden 2. Alcatel IdealXCITE Rear Speaker Replacement: adım 4, 3 resimden 3.
    • Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
    • Work the tool gently around the antenna to release it.
  5. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: adım 5, 3 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: adım 5, 3 resimden 2. Alcatel IdealXCITE Rear Speaker Replacement, Rear Speaker: adım 5, 3 resimden 3.
    • Remove the three 4mm PH00 screws holding the WiFi/GPS antenna in.
    • Gently pry the WiFi/GPS antenna out using a Jimmy and set aside.
  6. Alcatel IdealXCITE Rear Speaker Replacement: adım 6, 2 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the three remaining 4mm PH00 screws.
    • Remove the two 3mm PH00 screws.
  7. Alcatel IdealXCITE Rear Speaker Replacement: adım 7, 3 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement: adım 7, 3 resimden 2. Alcatel IdealXCITE Rear Speaker Replacement: adım 7, 3 resimden 3.
    • Using a spudger and an iFixit opening pick, pry the midframe up.
  8. Alcatel IdealXCITE Rear Speaker Replacement: adım 8, 3 resimden 1. Alcatel IdealXCITE Rear Speaker Replacement: adım 8, 3 resimden 2. Alcatel IdealXCITE Rear Speaker Replacement: adım 8, 3 resimden 3.
    • Pry gently between the rear case and speaker using an iFixit opening pick.
    • Reapply adhesive to the new speaker when reassembling the phone.
Sonuç
Franklin Froehlich
427 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 286
