Ana içeriğe geç
Alcatel Jitterbug Smart Battery Replacement
Neye ihtiyacın var
    1. Alcatel Jitterbug Smart  Battery Replacement, Battery: adım 1, 2 resimden 1. Alcatel Jitterbug Smart  Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
      • Lift open case by the corner nearest the divot and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Alcatel Jitterbug Smart  Battery Replacement: adım 2, 3 resimden 1. Alcatel Jitterbug Smart  Battery Replacement: adım 2, 3 resimden 2. Alcatel Jitterbug Smart  Battery Replacement: adım 2, 3 resimden 3.
      • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Alcatel Jitterbug Smart  Battery Replacement: adım 3, 2 resimden 1. Alcatel Jitterbug Smart  Battery Replacement: adım 3, 2 resimden 2.
      • Gently pry off the Mid frame from the phone using a Metal Spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Alcatel Jitterbug Smart  Battery Replacement: adım 4, 2 resimden 1. Alcatel Jitterbug Smart  Battery Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to pull the battery connector from its port.
      • Be careful not to tear the battery from its connection.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Gavin Le
523 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G4
4 Üyeler
35 adet Kılavuz yazıldı
5Kılavuz Yorumları
After reading my user guide, I searched how to replace a battery on a Jitterbug Smart2 and had several hits. I connected with this one: Alcatel Jitterbug Smart Battery Replacement 104708#. I see this is the site you have, so I began to follow instructions. When I took the back off of my phone, I saw it looks different from the one you show. Also, mine says this is a non-removeable battery. What do I do now?
Shirley Anderson - Yanıt Paylaş
I just called Great Call. They told me the battery is not replaceable. I’ll risk it anyway: What’s the point of a cordless phone that doesn’t work without a cord?
Robert L Lazzara - Yanıt Paylaş
I followed your directions step by step to remove the battery but on my Jitterbug Smart I, there are only 12 screws instead of 13! Your photo shows a screw in the middle near the camera lens but on my phone, that screw does not exist and the word void is printed in it’s place where the screw would be. Because of this, I was unable to remove the mid frame to get access to the battery. It seems to be stuck where the lens is situated making it impossible to remove and I don’t want to break it off.
Ed Johnston - Yanıt Paylaş
i'm sure it's too late for this comment to be helpful to the original poster, but the sticker that says VOID is covering the final screw and that's why it won't come off. that sticker is there so they can prove that you disassembled it and therefore voided your warranty.
David Jansen - Yanıt Paylaş
Jitterbug Smart 2 has a NON REMOVEABLE BATTERY. These bogus instructions sell a lot of U$ELE$$ batteries
Jerry Mobley - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 64
Her zaman: 18,326
