Ana içeriğe geç
Alcatel Jitterbug Smart Camera Replacement
Neye ihtiyacın var
  1. Alcatel Jitterbug Smart Camera Replacement, Rear Camera: adım 1, 2 resimden 1. Alcatel Jitterbug Smart Camera Replacement, Rear Camera: adım 1, 2 resimden 2.
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Alcatel Jitterbug Smart Camera Replacement: adım 2, 2 resimden 1. Alcatel Jitterbug Smart Camera Replacement: adım 2, 2 resimden 2.
    • Remove the 13 1 mm Phillips screws with JIS #000 Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Alcatel Jitterbug Smart Camera Replacement: adım 3, 2 resimden 1. Alcatel Jitterbug Smart Camera Replacement: adım 3, 2 resimden 2.
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
    FixBot'a Sor
    Yorum Ekle
  4. Alcatel Jitterbug Smart Camera Replacement: adım 4, 2 resimden 1. Alcatel Jitterbug Smart Camera Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the Plastic Opening tools to gently dislodge the broken camera from the inside of the phone.
    • Use a tweezers to pull the camera connector from its port.
    • Be careful not to tear the camera from its connection.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Gavin Le
523 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G4
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 601
