Ana içeriğe geç
Alcatel Jitterbug Smart Headphone Jack Replacement
Neye ihtiyacın var
  1. Alcatel Jitterbug Smart Headphone Jack Replacement, Battery: adım 1, 2 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement, Battery: adım 1, 2 resimden 2.
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 2, 3 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 2, 3 resimden 2. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 2, 3 resimden 3.
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
  3. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 3, 2 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 4, 2 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Alcatel Jitterbug Smart Headphone Jack Replacement, Motherboard: adım 5, 3 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement, Motherboard: adım 5, 3 resimden 2. Alcatel Jitterbug Smart Headphone Jack Replacement, Motherboard: adım 5, 3 resimden 3.
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
  6. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 6, 2 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 6, 2 resimden 2.
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
  7. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 7, 2 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement: adım 7, 2 resimden 2.
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
  8. Alcatel Jitterbug Smart Headphone Jack Replacement, Headphone Jack: adım 8, 2 resimden 1. Alcatel Jitterbug Smart Headphone Jack Replacement, Headphone Jack: adım 8, 2 resimden 2.
    • Flip the motherboard upside-down and desolder the pin connection of headphone jack to the motherboard.
    • Once pins desolder, pull the headphone jack out.
    • If you need helps on solder/desolder, here is the line to the soldering skills guide.
Sonuç
Minyu Zhang
181 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 201
