Ana içeriğe geç
Alcatel Jitterbug Smart Motherboard Replacement
Neye ihtiyacın var
  1. Alcatel Jitterbug Smart Motherboard Replacement, Battery: adım 1, 2 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift open case by the corner nearest the divot and remove it from the phone.
  2. Alcatel Jitterbug Smart Motherboard Replacement: adım 2, 3 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement: adım 2, 3 resimden 2. Alcatel Jitterbug Smart Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove 13 1mm JIS screws with JIS #000 Screwdriver.
  3. Alcatel Jitterbug Smart Motherboard Replacement: adım 3, 2 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently pry off the Mid frame from the phone using a Metal Spudger.
  4. Alcatel Jitterbug Smart Motherboard Replacement: adım 4, 2 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  5. Alcatel Jitterbug Smart Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Alcatel Jitterbug Smart Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
  6. Alcatel Jitterbug Smart Motherboard Replacement: adım 6, 2 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement: adım 6, 2 resimden 2.
    Satın Al
    • Use a pair of tweezers to pull the black ribbon connector from its port.
    • Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
    • Be careful to avoid damage the black connector or the wire connect the speaker to motherboard.
  7. Alcatel Jitterbug Smart Motherboard Replacement: adım 7, 2 resimden 1. Alcatel Jitterbug Smart Motherboard Replacement: adım 7, 2 resimden 2.
    • Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
    • The motherboard will freely remove.
Sonuç
Gavin Le
523 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G4, Cheng Spring 2018 USF Tampa, Team S11-G4, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 312
