Ana içeriğe geç
Alcatel One Touch Elevate (5017B) Motherboard Replacement
Neye ihtiyacın var
  1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: adım 1, 3 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: adım 1, 3 resimden 2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 2, 3 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 2, 3 resimden 2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 2, 3 resimden 3.
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: adım 3, 3 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: adım 3, 3 resimden 2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: adım 3, 3 resimden 3.
    • Using the Phillips screw driver, remove the 9 screws from the phone.
  4. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 4, 1 resimden 1.
    • Using your prying tool, place it between the screen and the back cover and pry it open.
  5. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 5, 2 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 5, 2 resimden 2.
    • Disconnect the camera from the mother board with your prying tool.
  6. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 6, 3 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 6, 3 resimden 2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 6, 3 resimden 3.
    • Remove both of this cables located on the bottom left corner of the phone.
  7. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 7, 2 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 7, 2 resimden 2.
    • Remove the volume and power button using your prying tool.
    • Go underneath the bronze plate with your prying tool and carefully pry it off.
  8. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 8, 1 resimden 1.
    • Remove this pice that is to the right of the camera with your prying tool.
  9. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 9, 2 resimden 1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 9, 2 resimden 2.
    • Remove this two pieces by using your tweezers.
    • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
  10. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: adım 10, 1 resimden 1.
    • Using you prying tool, go in-between the phone.
    • Carefully pry it off.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 270
