Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
  1. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents. Remove the back cover using one of the plastic opening tools and the slit in one of the corners. Be gentle when prying so as to not wear out the tool.
    • Turn off the phone before proceeding with disassembly to prevent shock and potential shorting of any electrical somponents.
    • Remove the back cover using one of the plastic opening tools and the slit in one of the corners.
    • Be gentle when prying so as to not wear out the tool.
  2. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
    • Remove the battery using one of the plastic opening tools and the dome-shaped indent next to the battery face.
  3. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
    • Unscrew the four 4mm JIS screws in each corner using the J000 screwdriver head. Turn the screws counter-clockwise to loosen.
  4. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose. Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose. Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
    • Insert a plastic or metal spudger between the front cover and rear frame in one of the areas indicated by the red squares and gently pry the rear frame loose. Repeat the process all the way around the phone until the rear frame comes loose.
  5. Bu adım çevrilmemiş. Çevrilmesine yardım edin
    Pull the rear frame off with your hands. Pull the rear frame off with your hands.
    • Pull the rear frame off with your hands.
Bitiş Çizgisi
Andrew Bai
634 İtibar
5 adet Kılavuz yazıldı
Takım
IUPUI, Team 1-3, Baechle Spring 2017 IUPUI, Team 1-3, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 758
