Giriş
Use this guide to replace the rear facing camera on your Alcatel One Touch Fierce.
  1. Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Remove the 11 Phillips #000 screws. The midframe should lift free. The midframe should lift free.
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  4. Use a pair of tweezers to gently disconnect the camera connector and remove the rear facing camera. Use a pair of tweezers to gently disconnect the camera connector and remove the rear facing camera.
    • Use a pair of tweezers to gently disconnect the camera connector and remove the rear facing camera.
Sonuç
6 başka kişi bu kılavuzu tamamladı.
Cody Stouffer
401 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S5G5
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 2,146
