Ana içeriğe geç
Alcatel One Touch Idol 3 Battery Replacement
Neye ihtiyacın var
  1. Alcatel One Touch Idol 3 Battery Replacement, Battery: adım 1, 3 resimden 1. Alcatel One Touch Idol 3 Battery Replacement, Battery: adım 1, 3 resimden 2. Alcatel One Touch Idol 3 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the sim tray by inserting a sim removal tool and then pulling it out.
  2. Alcatel One Touch Idol 3 Battery Replacement: adım 2, 3 resimden 1. Alcatel One Touch Idol 3 Battery Replacement: adım 2, 3 resimden 2. Alcatel One Touch Idol 3 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the back cover by moving around its perimeter with a thin object that can fit.
    • Eventually you will be able to pry open the back cover.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead.
  3. Alcatel One Touch Idol 3 Battery Replacement: adım 3, 2 resimden 1. Alcatel One Touch Idol 3 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the protective sticker from the battery connection.
  4. Alcatel One Touch Idol 3 Battery Replacement: adım 4, 2 resimden 1. Alcatel One Touch Idol 3 Battery Replacement: adım 4, 2 resimden 2.
    • Disconnect the battery's connection to the motherboard by lifting it upwards.
  5. Alcatel One Touch Idol 3 Battery Replacement: adım 5, 2 resimden 1. Alcatel One Touch Idol 3 Battery Replacement: adım 5, 2 resimden 2.
    • Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
    • Take care to not get isopropyl alcohol on any other parts of the phone.
  6. Alcatel One Touch Idol 3 Battery Replacement: adım 6, 3 resimden 1. Alcatel One Touch Idol 3 Battery Replacement: adım 6, 3 resimden 2. Alcatel One Touch Idol 3 Battery Replacement: adım 6, 3 resimden 3.
    • Pry out the battery by leveraging an object under the battery and lifting it upwards.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead. A razor could easily puncture the battery and create a hazard.
Sonuç
Eric Lopez
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 97
