Ana içeriğe geç
Alcatel One Touch Pop 7 Volume Button Assembly Replacement
Neye ihtiyacın var
  1. Alcatel One Touch Pop 7 Volume Button Assembly Replacement, Volume Button Assembly: adım 1, 1 resimden 1.
    • Begin working by using the plastic opening tool to remove the back cover of your Alcatel One Touch Pop 7. Opening the flap as shown in the picture will give you an easier start.
  2. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 2, 3 resimden 1. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 2, 3 resimden 2. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With the back cover removed you will now want to disconnect the battery. Use the tweezers and gently pull the wires as shown in the second picture.
  3. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 3, 2 resimden 1. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 3, 2 resimden 2.
    • The volume button assembly is in the top left corner of the tablet. To begin, you will have to pull the small black tab of the ZIF connector, shown in the second picture, to be able to remove the assembly. The tab is on a hinge so it should not be pulled off completely.
  4. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 4, 3 resimden 1. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 4, 3 resimden 2. Alcatel One Touch Pop 7 Volume Button Assembly Replacement: adım 4, 3 resimden 3.
    • Pull the copper ribbon cable from the tab. It should be easily removed, as the ZIF connector is the only thing holding it in place.
    • Next up is removing the volume button assembly. Another easy removal, simply pull the assembly away from the device and you're done with the removal process.
Sonuç
To reassemble your device, follow these instructions in reverse order with the new volume button assembly replacing the old one.
Bir başkası bu kılavuzu tamamladı.
Riley Cooper
926 İtibar
5 adet Kılavuz yazıldı
Ekip
Sam Houston State, Team 12-1, Blackburne Fall 2016 Sam Houston State, Team 12-1, Blackburne Fall 2016 üyesi
SHSU-BLACKBURNE-F16S12G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 1,023
