Ana içeriğe geç
Alcatel OneTouch Evolve Battery Removal
Neye ihtiyacın var
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: adım 1, 1 resimden 1.
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    FixBot'a Sor
    Yorum Ekle
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 1. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 3.
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: adım 3, 1 resimden 1.
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    FixBot'a Sor
    Yorum Ekle
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: adım 4, 2 resimden 1. Alcatel OneTouch Evolve Battery Removal, Removing the battery: adım 4, 2 resimden 2.
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Brendan Egan
2.491 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G5
3 Üyeler
18 adet Kılavuz yazıldı
5Kılavuz Yorumları
Thanks 4 the info.
dennisp1964 - Yanıt Paylaş
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Yanıt Paylaş
please replay
Thank you very much!
Kath B - Yanıt Paylaş
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 10,556
