Ana içeriğe geç
Alcatel OneTouch Evolve Battery Removal
Neye ihtiyacın var
  1. Alcatel OneTouch Evolve Battery Removal, Locate the access tab: adım 1, 1 resimden 1.
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 1. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 2. Alcatel OneTouch Evolve Battery Removal, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 3.
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Battery Removal, Identify the Battery: adım 3, 1 resimden 1.
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Battery Removal, Removing the battery: adım 4, 2 resimden 1. Alcatel OneTouch Evolve Battery Removal, Removing the battery: adım 4, 2 resimden 2.
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Brendan Egan
2.467 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G5
3 Üyeler
12 adet Kılavuz yazıldı
5 Yorum
Thanks 4 the info.
dennisp1964 - Yanıt
my phone is rooted
next time i,m delete all software
now my phone show only lock screen
how to install my old software
Noushad Marshi - Yanıt
Thank you very much!
Kath B - Yanıt
Easy and clear instructions! I am 95 yrs old and I found your instructions wonderful! Thank you Helen Spriggs
Helen Spriggs - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 9,998
