Ana içeriğe geç
Alcatel OneTouch Evolve Volume Control Button Replacement
Neye ihtiyacın var
  1. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate the access tab: adım 1, 1 resimden 1.
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    FixBot'a Sor
    Yorum Ekle
  2. Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 1. Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 2. Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: adım 2, 3 resimden 3.
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Alcatel OneTouch Evolve Volume Control Button Replacement, Identify the Battery: adım 3, 1 resimden 1.
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    FixBot'a Sor
    Yorum Ekle
  4. Alcatel OneTouch Evolve Volume Control Button Replacement, Removing the battery: adım 4, 2 resimden 1. Alcatel OneTouch Evolve Volume Control Button Replacement, Removing the battery: adım 4, 2 resimden 2.
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    FixBot'a Sor
    Yorum Ekle
  5. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate Screws Holding the Secondary Panel in Place: adım 5, 1 resimden 1.
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
    FixBot'a Sor
    Yorum Ekle
  6. Alcatel OneTouch Evolve Volume Control Button Replacement, Remove Screws: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
    FixBot'a Sor
    Yorum Ekle
  7. Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: adım 7, 3 resimden 1. Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: adım 7, 3 resimden 2. Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: adım 7, 3 resimden 3.
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
    FixBot'a Sor
    Yorum Ekle
  8. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate Volume Control Button: adım 8, 1 resimden 1.
    • This will be located in the top right of the back side of the secondary panel and will be clear in color.
    FixBot'a Sor
    Yorum Ekle
  9. Alcatel OneTouch Evolve Volume Control Button Replacement, Remove Volume Control Button: adım 9, 1 resimden 1.
    • Using the smaller pry tool, place the flat head on the area of the button exposed to the exterior, and push with slight pressure until the button is inside the secondary panel.
    • Using the tweezers, lift the clear rubber extensions of the volume buttons out of their tabs located inside the secondary panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brendan Egan
2.491 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Miles Fall 2014 UMass Dartmouth, Team 4-5, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G5
3 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
Thank so much for post/
Sonnerie France - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 3,401
