Giriş
Removing the battery is a quick and simple operation that will occasionally be needed in order to troubleshoot the phone.
Neye ihtiyacın var
Shut down the device
Flip the phone so that the screen is facing the surface you are working on
Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
2 farklı kişi bu kılavuzu tamamladı.
