Ana içeriğe geç
Alcatel OneTouch Pop Icon Interior Back Panel Replacement
Neye ihtiyacın var
  1. Alcatel OneTouch Pop Icon Interior Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Interior Back Panel Replacement: adım 2, 2 resimden 1. Alcatel OneTouch Pop Icon Interior Back Panel Replacement: adım 2, 2 resimden 2.
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Interior Back Panel Replacement, Interior Back Panel: adım 3, 1 resimden 1.
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Interior Back Panel Replacement: adım 4, 1 resimden 1.
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 662
