Ana içeriğe geç
Alcatel Pop 4 Plus Front Camera Replacement
Neye ihtiyacın var
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: adım 1, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Front Camera Replacement: adım 2, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement: adım 2, 2 resimden 2.
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Front Camera Replacement: adım 3, 1 resimden 1.
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Front Camera Replacement: adım 4, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement: adım 4, 2 resimden 2.
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: adım 5, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: adım 5, 2 resimden 2.
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Front Camera Replacement: adım 6, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement: adım 6, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Front Camera Replacement: adım 7, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement: adım 7, 2 resimden 2.
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Front Camera Replacement: adım 8, 2 resimden 1. Alcatel Pop 4 Plus Front Camera Replacement: adım 8, 2 resimden 2.
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Front Camera Replacement: adım 9, 1 resimden 1.
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: adım 10, 1 resimden 1.
    • Disconnect the camera from the motherboard using the flattened of a spudger.
Sonuç
peter achanccaray
123 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 280
