Ana içeriğe geç
Alcatel Pop 4 Plus Motherboard Replacement
Neye ihtiyacın var
    1. Alcatel Pop 4 Plus Motherboard Replacement, Battery: adım 1, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement, Battery: adım 1, 2 resimden 2.
      • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
      FixBot'a Sor
      Yorum Ekle
    2. Alcatel Pop 4 Plus Motherboard Replacement: adım 2, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement: adım 2, 2 resimden 2.
      • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
      FixBot'a Sor
      Yorum Ekle
    3. Alcatel Pop 4 Plus Motherboard Replacement: adım 3, 1 resimden 1.
      • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
      FixBot'a Sor
      Yorum Ekle
    4. Alcatel Pop 4 Plus Motherboard Replacement: adım 4, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement: adım 4, 2 resimden 2.
      • Use the flat end of the spudger disconnect the battery from the motherboard.
      • Use the flat end of the spudger tool to pry out the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
      • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
      • Slide the ribbon cable out of the socket.
      FixBot'a Sor
      Yorum Ekle
    2. Alcatel Pop 4 Plus Motherboard Replacement: adım 6, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement: adım 6, 2 resimden 2.
      • Use the flat end of a spudger to disconnect the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    3. Alcatel Pop 4 Plus Motherboard Replacement: adım 7, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement: adım 7, 2 resimden 2.
      • Using the flat end of the spudger to disconnect the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    4. Alcatel Pop 4 Plus Motherboard Replacement: adım 8, 2 resimden 1. Alcatel Pop 4 Plus Motherboard Replacement: adım 8, 2 resimden 2.
      • Using the flat end of the spudger, disconnect the camera from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Alcatel Pop 4 Plus Motherboard Replacement: adım 9, 1 resimden 1.
      • Use the flat end of the spudger to pry off the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Pieter Molenaar
253 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G6
4 Üyeler
54 adet Kılavuz yazıldı
1Rehber Yorum
Hi
I got my Alcatel Pop 4+ checked and it's Power IC was faulty. How can I replace it
I'm looking for the specific IC used in it if I can get any help regarding it.
NINJA WARRIORS - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 1,405
