Ana içeriğe geç
Alcatel Pop 4 Plus Rear Camera Replacement
Neye ihtiyacın var
  1. Alcatel Pop 4 Plus Rear Camera Replacement, Battery: adım 1, 2 resimden 1. Alcatel Pop 4 Plus Rear Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Rear Camera Replacement: adım 2, 2 resimden 1. Alcatel Pop 4 Plus Rear Camera Replacement: adım 2, 2 resimden 2.
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Rear Camera Replacement: adım 3, 1 resimden 1.
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Rear Camera Replacement: adım 4, 2 resimden 1. Alcatel Pop 4 Plus Rear Camera Replacement: adım 4, 2 resimden 2.
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Rear Camera Replacement, Rear Camera: adım 5, 1 resimden 1.
    • Use the flat end of the spudger tool to remove the connector.
  6. Alcatel Pop 4 Plus Rear Camera Replacement: adım 6, 1 resimden 1.
    • Pry out the camera with the pointy end of the spudger tool.
Sonuç
Maalik Poleon
202 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S20-G6, Passmore Spring 2018 USF Tampa, Team S20-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S20G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 237
