Ana içeriğe geç
Alienware 15 R2 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Alienware 15 R2 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Alienware 15 R2 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Place laptop upside down with the hinge facing you, then remove the two 9.0 mm Phillips #0 screws located in the center of the rear panel.
    • Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
    • Be sure to use your Anti-Static wrist strap for this process. Hard drives are susceptible to static damage!
    FixBot'a Sor
    Yorum Ekle
  2. Alienware 15 R2 Hard Drive Replacement: adım 2, 2 resimden 1. Alienware 15 R2 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening tool to disconnect the battery cable.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware 15 R2 Hard Drive Replacement: adım 3, 2 resimden 1. Alienware 15 R2 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use the T9 Torx bit to remove the screws on the hard drive cover.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware 15 R2 Hard Drive Replacement: adım 4, 2 resimden 1. Alienware 15 R2 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Firmly pull on the plastic tab to remove connector from motherboard and remove the hard drive from it's slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 2,202
