Ana içeriğe geç
Alienware 15 R3 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware 15 R3  Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Alienware 15 R3  Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Alienware 15 R3  Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Find Power in start menu and click Shut Down to turn off your Alienware 15 R3.
    • Wait a few seconds until all the lights around are off.
    • Unplug the power supply.
  2. Alienware 15 R3  Hard Drive Replacement: adım 2, 3 resimden 1. Alienware 15 R3  Hard Drive Replacement: adım 2, 3 resimden 2. Alienware 15 R3  Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the seven M2.5x13 screws from the base cover.
    • Remove the base cover carefully.
    • Save these screws for later.
    • The screw on the top middle of base cover cannot be removed after unscrewing. But it is okay to remove the base cover.
  3. Alienware 15 R3  Hard Drive Replacement: adım 3, 3 resimden 1. Alienware 15 R3  Hard Drive Replacement: adım 3, 3 resimden 2. Alienware 15 R3  Hard Drive Replacement: adım 3, 3 resimden 3.
    • Remove the two M3x3 screws that are holding the bracket and one M2.5x8 screw holding the hard drive assembly .
  4. Alienware 15 R3  Hard Drive Replacement: adım 4, 2 resimden 1. Alienware 15 R3  Hard Drive Replacement: adım 4, 2 resimden 2.
    • Put bottom plate back on your laptop and secure the bottom plate with the screws removed previously.
    • Prior to reassembly, clean the dust on fans as circled in picture if needed.
  5. Alienware 15 R3  Hard Drive Replacement: adım 5, 1 resimden 1.
    • Your Alienware 15 R3 is ready to roll.
Sonuç
By removing the HDD from the laptop, BSOD will never happen again when you boot the laptop. Please note that, the storage space than it was in the past.
Bir başkası bu kılavuzu tamamladı.
Yutong Yin
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 1,295
