Ana içeriğe geç
Alienware 15 R3 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware 15 R3 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Alienware 15 R3 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Alienware 15 R3 Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Find the Power option in the start menu and click Shut Down to turn off your Alienware 15 R3.
    • Wait a few seconds until all the computer's lights are off.
    • Unplug the power supply.
  2. Alienware 15 R3 Hard Drive Replacement: adım 2, 3 resimden 1. Alienware 15 R3 Hard Drive Replacement: adım 2, 3 resimden 2. Alienware 15 R3 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the seven M2.5x13 screws from the base cover.
    • Remove the base cover carefully.
    • Save these screws for later.
    • The screw on the top middle of the base cover cannot be removed after unscrewing. However, it is okay to remove the base cover.
  3. Alienware 15 R3 Hard Drive Replacement: adım 3, 3 resimden 1. Alienware 15 R3 Hard Drive Replacement: adım 3, 3 resimden 2. Alienware 15 R3 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Remove the two M3x3 screws that are holding the bracket and the one M2.5x8 screw holding the hard drive assembly.
    • Remove the hard drive from the laptop.
  4. Alienware 15 R3 Hard Drive Replacement: adım 4, 2 resimden 1. Alienware 15 R3 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Prior to reassembly, clean the dust from the fans as circled in the picture if needed.
    • Put the bottom plate back on your laptop and secure it with the screws removed previously.
  5. Alienware 15 R3 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Your Alienware 15 R3 is ready to roll!
Sonuç
By removing the HDD, the Blue Screen of Death should not occur anymore when booting the laptop. Please note that the volume of storage on your computer may change.
2 farklı kişi bu kılavuzu tamamladı.
Yutong Yin
166 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,720
