Ana içeriğe geç
  1. Alienware 17 R2  Screen Replacement, Display: adım 1, 1 resimden 1.
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: adım 2, 2 resimden 1. Alienware 17 R2  Screen Replacement: adım 2, 2 resimden 2.
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: adım 3, 2 resimden 1. Alienware 17 R2  Screen Replacement: adım 3, 2 resimden 2.
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: adım 4, 3 resimden 1. Alienware 17 R2  Screen Replacement: adım 4, 3 resimden 2. Alienware 17 R2  Screen Replacement: adım 4, 3 resimden 3.
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: adım 5, 2 resimden 1. Alienware 17 R2  Screen Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: adım 6, 1 resimden 1.
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: adım 7, 1 resimden 1.
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: adım 8, 1 resimden 1.
    • Gently, lift the display away from the laptop.
Sonuç
Luis Garcia
402 İtibar
4 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 31
Her zaman: 2,760
