Ana içeriğe geç
Alienware 17 R2 Base Panel Replacement
Neye ihtiyacın var
  1. Alienware 17 R2 Base Panel Replacement, Close the Display: adım 2, 1 resimden 1.
    • Close the display and turn the computer over.
    • Make sure PC is turned off!
  2. Alienware 17 R2 Base Panel Replacement, Loosen Screws: adım 3, 1 resimden 1.
    • Loosen the captive screws that secure the base panel to the computer base.
  3. Alienware 17 R2 Base Panel Replacement, Releasing Tabs: adım 4, 1 resimden 1.
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
  4. Alienware 17 R2 Base Panel Replacement, Remove Base Panel: adım 5, 1 resimden 1.
    • Slide and remove the base panel from the computer base.
  5. Alienware 17 R2 Base Panel Replacement, Disconnect Battery Cable: adım 6, 1 resimden 1.
    • Disconnect the Battery cable from the system board.
    • Turn the computer over.
    • Press and hold power button for 5 seconds to ground the system board.
  6. Alienware 17 R2 Base Panel Replacement, Battery Cable: adım 9, 1 resimden 1.
    • Connect the battery cable to the system board.
  7. Alienware 17 R2 Base Panel Replacement, Tighten Screws: adım 10, 1 resimden 1.
    • Tighten the captive screws that secure the base panel to the computer base.
Sonuç
Terrence15
80.125 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.002 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 65
Her zaman: 1,192
