Ana içeriğe geç
Alienware 17 R2 Keyboard Replacement
Neye ihtiyacın var
    1. FixBot'a Sor
      Yorum Ekle
    2. Alienware 17 R2 Keyboard Replacement, Close the Display: adım 2, 1 resimden 1.
      • Close the display and turn the computer over.
      • Make sure PC is turned off!
      FixBot'a Sor
      Yorum Ekle
    3. Alienware 17 R2 Keyboard Replacement, Loosen Screws: adım 3, 1 resimden 1.
      • Loosen the captive screws that secure the base panel to the computer base.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware 17 R2 Keyboard Replacement, Releasing Tabs: adım 4, 1 resimden 1.
      • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware 17 R2 Keyboard Replacement, Remove Base Panel: adım 5, 1 resimden 1.
      • Slide and remove the base panel from the computer base.
      FixBot'a Sor
      Yorum Ekle
    6. Alienware 17 R2 Keyboard Replacement, Disconnect Battery Cable: adım 6, 1 resimden 1.
      • Disconnect the Battery cable from the system board.
      FixBot'a Sor
      Yorum Ekle
      • Turn the computer over.
      FixBot'a Sor
      Yorum Ekle
      • Press and hold power button for 5 seconds to ground the system board.
      FixBot'a Sor
      Yorum Ekle
    7. Alienware 17 R2 Keyboard Replacement, Battery Cable: adım 9, 1 resimden 1.
      • Connect the battery cable to the system board.
      FixBot'a Sor
      Yorum Ekle
    8. Alienware 17 R2 Keyboard Replacement, Tighten Screws: adım 10, 1 resimden 1.
      • Tighten the captive screws that secure the base panel to the computer base.
      FixBot'a Sor
      Yorum Ekle
      • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Make sure the base panel is removed.
      • Make sure palm rest is removed.
      • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware 17 R2 Keyboard Replacement, Peel off the Cables: adım 12, 1 resimden 1.
      • Note the touch-pad cable and status-light cable routing and peel off the cables from the keyboard bracket.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware 17 R2 Keyboard Replacement, Screw Removal: adım 13, 1 resimden 1.
      • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
      • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the keyboard bracket.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard Bracket: adım 15, 1 resimden 1.
      • Lift the keyboard bracket off the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware 17 R2 Keyboard Replacement: adım 16, 1 resimden 1.
      • Remove the screws that secure the keyboard to the palm rest assembly.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware 17 R2 Keyboard Replacement, Releasing the Tabs: adım 17, 1 resimden 1.
      • Release the tabs that secure the keyboard to the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
    6. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard: adım 18, 1 resimden 1.
      • Slide and lift the keyboard along with the cables off the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
      • Slide the new keyboard under the tabs on the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
    7. Alienware 17 R2 Keyboard Replacement, Screw Alignment: adım 20, 1 resimden 1.
      • Align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
      • Replace the screws that secure the keyboard to the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
      • Route the keyboard cable, keyboard-backlight cable, marco-keys cable and marco-keys backlight cable through the slots on the keyboard bracket.
      FixBot'a Sor
      Yorum Ekle
      • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
    8. Alienware 17 R2 Keyboard Replacement, Replace the Screws: adım 24, 1 resimden 1.
      • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
      FixBot'a Sor
      Yorum Ekle
      • Adhere the touch-pad cable and status-light cable to the keyboard bracket.
      FixBot'a Sor
      Yorum Ekle
      • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Terrence15
80.125 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.124 adet Kılavuz yazıldı
1Rehber Yorum
I find it concerning that this guide has you disconnect and reconnect the battery prior to doing anything with the keyboard.
Sean Hanson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 2,903
