Ana içeriğe geç
Alienware 17 R3 Display Replacement
Neye ihtiyacın var
    1. Alienware 17 R3 Display Replacement, Display: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      Anti-Static Wrist Strap
      $7.95
      • Turn the computer off.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
      • Flip the computer upside down.
      • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware 17 R3 Display Replacement: adım 2, 1 resimden 1.
      • Unscrew and remove the two 4mm Phillips screws from cover.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware 17 R3 Display Replacement: adım 3, 1 resimden 1.
      • Pull up and slide cover off.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware 17 R3 Display Replacement: adım 4, 2 resimden 1. Alienware 17 R3 Display Replacement: adım 4, 2 resimden 2.
      • Unplug the black wire with the yellow tag to disconnect the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware 17 R3 Display Replacement: adım 5, 1 resimden 1.
      • Using the plastic opening tool, pull display casing away from main body.
      FixBot'a Sor
      Yorum Ekle
    6. Alienware 17 R3 Display Replacement: adım 6, 1 resimden 1.
      • Unscrew and remove the two 2mm Phillips screws from the bottom of the display.
      FixBot'a Sor
      Yorum Ekle
    7. Alienware 17 R3 Display Replacement: adım 7, 1 resimden 1.
      • Disconnect plugs connecting the display to the main body.
      FixBot'a Sor
      Yorum Ekle
    8. Alienware 17 R3 Display Replacement: adım 8, 1 resimden 1.
      • Lift display out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Jonathon Tschurwald
878 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-1, Rose Winter 2017 UW Tacoma, Team 1-1, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G1
3 Üyeler
47 adet Kılavuz yazıldı
1Rehber Yorum
The best and easiest way to replace the screen!
Jhun Calvin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 66
Her zaman: 5,032
