Ana içeriğe geç
Alienware 17 R3 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware 17 R3 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap to prevent any electrical shock to the components. Shocks may damage the components.
  2. Alienware 17 R3 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove the two 4mm Phillips #1 screws from the cover.
  3. Alienware 17 R3 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull up and slide the cover off.
  4. Alienware 17 R3 Hard Drive Replacement: adım 4, 2 resimden 1. Alienware 17 R3 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Unplug the black wire with the yellow tag to disconnect the battery.
  5. Alienware 17 R3 Hard Drive Replacement: adım 5, 2 resimden 1. Alienware 17 R3 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
  6. Alienware 17 R3 Hard Drive Replacement: adım 6, 2 resimden 1. Alienware 17 R3 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
  7. Alienware 17 R3 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the plug from the Hard Drive.
  8. Alienware 17 R3 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Lift the Hard Drive out.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jonathon Tschurwald
869 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-1, Rose Winter 2017 UW Tacoma, Team 1-1, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G1
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 4,964
