Ana içeriğe geç
Alienware 17 R4 Fan Shroud Replacement
Neye ihtiyacın var
  1. Alienware 17 R4 Fan Shroud Replacement, Base Cover: adım 1, 1 resimden 1.
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Fan Shroud Replacement: adım 2, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 2, 2 resimden 2.
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Fan Shroud Replacement, Hard Disk Drive (HDD): adım 3, 3 resimden 1. Alienware 17 R4 Fan Shroud Replacement, Hard Disk Drive (HDD): adım 3, 3 resimden 2. Alienware 17 R4 Fan Shroud Replacement, Hard Disk Drive (HDD): adım 3, 3 resimden 3.
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Fan Shroud Replacement: adım 4, 3 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 4, 3 resimden 2. Alienware 17 R4 Fan Shroud Replacement: adım 4, 3 resimden 3.
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Fan Shroud Replacement: adım 5, 3 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 5, 3 resimden 2. Alienware 17 R4 Fan Shroud Replacement: adım 5, 3 resimden 3.
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Fan Shroud Replacement: adım 6, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 6, 2 resimden 2.
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Fan Shroud Replacement, RAM: adım 7, 3 resimden 1. Alienware 17 R4 Fan Shroud Replacement, RAM: adım 7, 3 resimden 2. Alienware 17 R4 Fan Shroud Replacement, RAM: adım 7, 3 resimden 3.
    • Move the metal sidings outward to release the RAM card.
  8. Alienware 17 R4 Fan Shroud Replacement: adım 8, 1 resimden 1.
    • Slide the RAM card out towards yourself to remove it.
    • Repeat the same step for the RAM card above.
    • Slide the RAM card out carefully to avoid damaging it.
  9. Alienware 17 R4 Fan Shroud Replacement, Wi-Fi card: adım 9, 1 resimden 1.
    • Locate the WI-FI card.
  10. Alienware 17 R4 Fan Shroud Replacement: adım 10, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 10, 2 resimden 2.
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  11. Alienware 17 R4 Fan Shroud Replacement: adım 11, 3 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 11, 3 resimden 2. Alienware 17 R4 Fan Shroud Replacement: adım 11, 3 resimden 3.
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  12. Alienware 17 R4 Fan Shroud Replacement: adım 12, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 12, 2 resimden 2.
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
  13. Alienware 17 R4 Fan Shroud Replacement, Solid State Drive: adım 13, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement, Solid State Drive: adım 13, 2 resimden 2.
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  14. Alienware 17 R4 Fan Shroud Replacement: adım 14, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 14, 2 resimden 2.
    • Slide the solid state drive towards yourself to prevent damage to the card.
  15. Alienware 17 R4 Fan Shroud Replacement, Fan Shroud: adım 15, 3 resimden 1. Alienware 17 R4 Fan Shroud Replacement, Fan Shroud: adım 15, 3 resimden 2. Alienware 17 R4 Fan Shroud Replacement, Fan Shroud: adım 15, 3 resimden 3.
    • Remove the two M2.5x7 screws (2.44 mm) located on the rear panel using a PH1 screwdriver bit.
  16. Alienware 17 R4 Fan Shroud Replacement: adım 16, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 16, 2 resimden 2.
    • Insert the plastic opening tool under the fan shroud to slowly lift it up.
    • Repeat process on the middle and opposite side.
  17. Alienware 17 R4 Fan Shroud Replacement: adım 17, 2 resimden 1. Alienware 17 R4 Fan Shroud Replacement: adım 17, 2 resimden 2.
    • Firmly lift the plastic opening tool and pull the fan shroud towards you.
    • This will take a large amount of force and will not come out easily the first time.
    • Careful not to tear out the piece causing damage to the fan shroud
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Hector Mendez III
1.280 İtibar
8 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G4
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 6,229
