Giriş
This guide will teach you how to replace your RAM card allowing you to upgrade or simply replace your card.
Neye ihtiyacın var
Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
Bir başkası bu kılavuzu tamamladı.
