Ana içeriğe geç
Alienware 17 R4 Solid State Drive (SSD) Replacement
Neye ihtiyacın var
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: adım 1, 1 resimden 1.
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 2, 2 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 2, 2 resimden 2.
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): adım 3, 3 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): adım 3, 3 resimden 2. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): adım 3, 3 resimden 3.
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 4, 3 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 4, 3 resimden 2. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 4, 3 resimden 3.
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 5, 3 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 5, 3 resimden 2. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 5, 3 resimden 3.
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 6, 2 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 6, 2 resimden 2.
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: adım 7, 2 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: adım 7, 2 resimden 2.
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 8, 2 resimden 1. Alienware 17 R4 Solid State Drive (SSD) Replacement: adım 8, 2 resimden 2.
    • Slide the solid state drive towards yourself to prevent damage to the card.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Hector Mendez III
1.280 İtibar
8 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G4
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 6,764
