Ana içeriğe geç
Alienware 17 R4 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: adım 1, 1 resimden 1.
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: adım 2, 2 resimden 1. Alienware 17 R4 Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: adım 3, 1 resimden 1.
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Alienware 17 R4 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: adım 5, 3 resimden 1. Alienware 17 R4 Wi-Fi Card Replacement: adım 5, 3 resimden 2. Alienware 17 R4 Wi-Fi Card Replacement: adım 5, 3 resimden 3.
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: adım 6, 2 resimden 1. Alienware 17 R4 Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hector Mendez III
1.340 İtibar
8 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G4, Bruce Fall 2017 CSU Fullerton, Team S2-G4, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G4
4 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 43
Her zaman: 5,088
