Giriş
The motherboard is the central component of the Alienware AW610M mouse. It connects and powers all other parts. Damage, wear, or electrical failure can lead to performance issues like unresponsive clicks, erratic cursor movement, or complete power loss. Replacing the motherboard should restore full functionality and ensure reliable performance.
This guide assumes a basic familiarity with disassembling electronic devices and handling delicate components. Before starting the replacement, make sure the mouse is completely turned off as well as unplugged to avoid any accidental breakage or shortage of wires. If you are unsure about the motherboard being the source of the problem, refer back to our troubleshooting page before you continue.
Neye ihtiyacın var
Remove the single 5.4 mm screw using a Phillips #1 screwdriver.
Detach the cable connector, and remove the scroll wheel.
Gently detach the last connector using your fingers.
