Ana içeriğe geç
Alienware AW610M Mouse Feet Replacement
Neye ihtiyacın var
    1. Alienware AW610M Mouse Feet Replacement, Mouse Feet: adım 1, 3 resimden 1. Alienware AW610M Mouse Feet Replacement, Mouse Feet: adım 1, 3 resimden 2. Alienware AW610M Mouse Feet Replacement, Mouse Feet: adım 1, 3 resimden 3.
      • Power off the mouse and disconnect any wired connections.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware AW610M Mouse Feet Replacement: adım 2, 2 resimden 1. Alienware AW610M Mouse Feet Replacement: adım 2, 2 resimden 2.
      • Use a spudger to gently lift and remove the old mouse feet.
      • If the feet are sticky, try lifting slowly from one corner to avoid tearing them.
      • Be careful not to scratch the mouse surface or damage the plastic housing.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware AW610M Mouse Feet Replacement: adım 3, 2 resimden 1. Alienware AW610M Mouse Feet Replacement: adım 3, 2 resimden 2.
      • Take a lint free cloth lightly dampened and clean away any remaining adhesive residue.
      • Allow the surface to dry completely before applying new feet to ensure proper adhesion.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware AW610M Mouse Feet Replacement: adım 4, 3 resimden 1. Alienware AW610M Mouse Feet Replacement: adım 4, 3 resimden 2. Alienware AW610M Mouse Feet Replacement: adım 4, 3 resimden 3.
      • Peel the adhesive backing off the new mouse feet. Align the mouse foot with its designated area on the mouse. Press firmly to secure it in place. Repeat steps for bottom mouse foot.
      • Make sure the feet are properly aligned before pressing, as misalignment can affect mouse performance.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware AW610M Mouse Feet Replacement: adım 5, 3 resimden 1. Alienware AW610M Mouse Feet Replacement: adım 5, 3 resimden 2. Alienware AW610M Mouse Feet Replacement: adım 5, 3 resimden 3.
      • Power the mouse back on via wired or wireless connection and test the glide and tracking on a smooth surface.
      • If the mouse still tracks poorly, check the surface or sensor for dust or debris.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ashley S.
171 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 46-4, Johansen Fall 2025 Texas Tech, Team 46-4, Johansen Fall 2025 üyesi
TTU-JOHANSEN-F25S46G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 57
Her zaman: 304
