Ana içeriğe geç
Alienware AW610M Scroll Wheel Replacement
Neye ihtiyacın var
  1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: adım 1, 3 resimden 1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: adım 1, 3 resimden 2. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: adım 1, 3 resimden 3.
    • Turn your mouse over with the scroll wheel facing down.
    • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
    • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
  2. Alienware AW610M Scroll Wheel Replacement: adım 2, 2 resimden 1. Alienware AW610M Scroll Wheel Replacement: adım 2, 2 resimden 2.
    • Turn your blowdryer on a low heat setting.
    • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
    • Turn off your blowdryer, unplug the device, and set it aside to cool down.
    • Carefully peel off the stickers, and set aside as well.
  3. Alienware AW610M Scroll Wheel Replacement: adım 3, 3 resimden 1. Alienware AW610M Scroll Wheel Replacement: adım 3, 3 resimden 2. Alienware AW610M Scroll Wheel Replacement: adım 3, 3 resimden 3.
    • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
  4. Alienware AW610M Scroll Wheel Replacement: adım 4, 1 resimden 1.
    • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
    • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
  5. Alienware AW610M Scroll Wheel Replacement: adım 5, 3 resimden 1. Alienware AW610M Scroll Wheel Replacement: adım 5, 3 resimden 2. Alienware AW610M Scroll Wheel Replacement: adım 5, 3 resimden 3.
    • Disconnect any wire connections away from the mouse's circuit board.
    • Locate the scroll wheel placed in the gap of the mouse's backing.
    • My scroll wheel was crooked, most likely causing my issue.
    • Gently lift the scroll wheel mechanism out of the mouse's backing.
  6. Alienware AW610M Scroll Wheel Replacement: adım 6, 3 resimden 1. Alienware AW610M Scroll Wheel Replacement: adım 6, 3 resimden 2. Alienware AW610M Scroll Wheel Replacement: adım 6, 3 resimden 3.
    • Disconnect the scroll wheel sensor from the mouse backing.
    • Remove the old wheel from the plastic casing, and set it aside.
    • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
  7. Alienware AW610M Scroll Wheel Replacement: adım 7, 3 resimden 1. Alienware AW610M Scroll Wheel Replacement: adım 7, 3 resimden 2. Alienware AW610M Scroll Wheel Replacement: adım 7, 3 resimden 3.
    • Dip a cotton swab into hydrogen-peroxide.
    • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
    • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
    • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rana Ashour
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 64
Son 30 gün: 361
Her zaman: 1,485
