Ana içeriğe geç
Alienware Area-51m battery Replacement
Neye ihtiyacın var
  1. Alienware Area-51m battery Replacement, battery: adım 1, 3 resimden 1. Alienware Area-51m battery Replacement, battery: adım 1, 3 resimden 2. Alienware Area-51m battery Replacement, battery: adım 1, 3 resimden 3.
    • turn off the laptop and remove all the cable connect to your laptop.
    • Place the back of the laptop up.
    • Remove 6 M2.5X8 computer base screws on the baseplate.
  2. Alienware Area-51m battery Replacement: adım 2, 3 resimden 1. Alienware Area-51m battery Replacement: adım 2, 3 resimden 2. Alienware Area-51m battery Replacement: adım 2, 3 resimden 3.
    • this is how it looks like when you take off the baseplate.
    • remove the cable connect with battery and main board.
    • Remove all 6 M2.5X5 battery screws around the battery.
  3. Alienware Area-51m battery Replacement: adım 3, 2 resimden 1. Alienware Area-51m battery Replacement: adım 3, 2 resimden 2.
    • take off the battery and use your new battery to instead.
    • this is how it looks like when you take off the battery(for some reason i take off the hard disk as well, you don't need to care about that.)
  4. Alienware Area-51m battery Replacement: adım 4, 3 resimden 1. Alienware Area-51m battery Replacement: adım 4, 3 resimden 2. Alienware Area-51m battery Replacement: adım 4, 3 resimden 3.
    • now you just need to put everything back.And do not forget to put the screws back also.
Sonuç
When reassembling your device, follow the instructions in reverse order.
yupeng ge
1 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 1,655
