Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
turn off the laptop and remove all the cable connect to your laptop.
Place the back of the laptop up.
Remove 6 M2.5X8 computer base screws on the baseplate.
this is how it looks like when you take off the baseplate.
remove the cable connect with battery and main board.
Remove all 6 M2.5X5 battery screws around the battery.
take off the battery and use your new battery to instead.
this is how it looks like when you take off the battery(for some reason i take off the hard disk as well, you don't need to care about that.)
now you just need to put everything back.And do not forget to put the screws back also.
