Ana içeriğe geç
Alienware Aurora M9700 Camera Replacement
Neye ihtiyacın var
  1. Alienware Aurora M9700 Camera Replacement, Camera: adım 1, 1 resimden 1.
    • Open the device so the main screen is facing forward.
    • Locate the 8 rubber buttons around the bezel of the display and remove the rubber buttons with the metal spudger to expose the screws underneath.
    • Locate the 8 screws around the perimeter of the screen and unscrew them.
  2. Alienware Aurora M9700 Camera Replacement: adım 2, 2 resimden 1. Alienware Aurora M9700 Camera Replacement: adım 2, 2 resimden 2.
    • Insert the plastic opening tool between the black and green frames to remove the display frame at the bottom of the display.
    • Slide the lock to the right when removing the display frame.
    • Remove the frame display.
  3. Alienware Aurora M9700 Camera Replacement: adım 3, 2 resimden 1. Alienware Aurora M9700 Camera Replacement: adım 3, 2 resimden 2.
    • Now that the outer frame is removed, locate the two screws to the right and the left of the camera.
    • Remove the two screws freeing the camera of the brackets holding it in place.
    • Pry the camera upward from its designated location using the metal spudger.
  4. Alienware Aurora M9700 Camera Replacement: adım 4, 2 resimden 1. Alienware Aurora M9700 Camera Replacement: adım 4, 2 resimden 2.
    • Unplug the wire connection between the camera and the laptop.
Sonuç
Jasmine Anchondo
679 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 210
