Giriş
This guide will allow you to not only open up your Alienware Desktop, but also show how to replace/add in an SSD hard drive. Modern Alienware desktops are notorious for squeezing as much hardware into the smallest space possible; as a result, gaining access to the hardware can be a bit tricky. This guide will illustrate how to access the hard drive slots, and how to add, remove, or replace your SSD hard drives with the least amount of hassle.
Neye ihtiyacın var
Remove the single 4 mm, M3x4 screw using the Phillips #00 screwdriver.
Slide one of the two switches on the rear panel of the computer upwards to unlock the mechanism that allows the power supply to be elevated.
Repeat the previous bullet to unlock the second switch.
Plug the SATA cable into the computer and the hard drive. The SATA cable plugs into the smaller connector on the right side of the hard drive, and just beneath the graphics card inside the computer.
Plug the power supply cable into the hard drive. The power supply cable plugs into the larger connector on the left side of the hard drive.
Once everything is done, close the computer by following the first two steps in reverse order. Your new hard drive is now ready to be used!
