Ana içeriğe geç
Alienware M11x Display Assembly Replacement
Neye ihtiyacın var
    1. Alienware M11x Display Assembly Replacement, Introduction: adım 1, 1 resimden 1.
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • NOTE: Dell or Alienware does not guarantee compatibility or provide support for hard drives from sources other than Dell.
      • NOTE: If you are installing a hard drive from a source other than Dell or Alienware, you need to install an operating system, drivers, and utilities on the new hard drive.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M11x Display Assembly Replacement, Loosen the Screws: adım 2, 1 resimden 1.
      • Loosen the two captive screws that secure the hard-drive assembly to the computer base.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M11x Display Assembly Replacement, Disconnecting the Hard-Drive: adım 3, 1 resimden 1.
      • Using the pull-tab, pull the hard-drive assembly to disconnect the hard-drive assembly from the connector on the system board.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware M11x Display Assembly Replacement, Lifting the Hard-Drive Assembly: adım 4, 1 resimden 1.
      • Lift the hard-drive assembly out of the computer base.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware M11x Display Assembly Replacement, Removing the Screws from the Hard-Drive: adım 5, 1 resimden 1.
      • Remove the four screws that secure the hard drive to the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    6. Alienware M11x Display Assembly Replacement, Removing the Bracket: adım 6, 1 resimden 1.
      • Lift the hard drive away from the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    7. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: adım 7, 1 resimden 1.
      • Place the NEW hard drive in the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    8. Alienware M11x Display Assembly Replacement, Replace the Screws: adım 8, 1 resimden 1.
      • Replace the four screws that secure the hard-drive to the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    9. Alienware M11x Display Assembly Replacement, Placing the Hard-Drive: adım 9, 1 resimden 1.
      • Place the hard-drive assembly in the computer base.
      FixBot'a Sor
      Yorum Ekle
    10. Alienware M11x Display Assembly Replacement, Connecting the Hard-Drive Assembly: adım 10, 1 resimden 1.
      • Use the pull-tab to push the hard drive assembly and connect it to the connector on the system board.
      FixBot'a Sor
      Yorum Ekle
    11. Alienware M11x Display Assembly Replacement, Securing the Screws: adım 11, 1 resimden 1.
      • Tighten the two captive screws that secure the hard-drive assembly to the computer base.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
darrius
5.213 İtibar
30 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.274 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 29
Her zaman: 1,165
