Ana içeriğe geç
Alienware M11xR2 Battery Pack Replacement
Neye ihtiyacın var
  1. Alienware M11xR2 Battery Pack Replacement, Removing the Base Cover: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Battery Pack Replacement, Loosen the Screws: adım 2, 1 resimden 1.
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Battery Pack Replacement, Lifting the Base Cover: adım 3, 1 resimden 1.
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Battery Pack Replacement, Replacing the Base Cover: adım 4, 1 resimden 1.
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Battery Pack Replacement, Securing the Screws: adım 5, 1 resimden 1.
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Battery Pack Replacement, Removing Screws: adım 6, 1 resimden 1.
    • Remove the two screws that secure the battery pack to the computer base.
  7. Alienware M11xR2 Battery Pack Replacement, Disconnecting cable: adım 7, 1 resimden 1.
    • Disconnect the battery pack cable from the connector on the system board.
  8. Alienware M11xR2 Battery Pack Replacement, Lifting Battery Pack: adım 8, 1 resimden 1.
    • Using the pull-tab, lift the battery pack off the computer base.
  9. Alienware M11xR2 Battery Pack Replacement, Placing New Battery Pack: adım 9, 1 resimden 1.
    • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
  10. Alienware M11xR2 Battery Pack Replacement, Routing Battery Pack: adım 10, 1 resimden 1.
    • Route the battery pack cable in the routing guide
  11. Alienware M11xR2 Battery Pack Replacement, Connnecting Battery Pack: adım 11, 1 resimden 1.
    • Connect the battery pack cable to the connector on the system board.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
darrius
5.213 İtibar
30 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.991 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 371
