Ana içeriğe geç
Alienware M11xR2 Display Assembly Replacement
Neye ihtiyacın var
    1. Alienware M11xR2 Display Assembly Replacement, Disconnecting Antenna Cable: adım 1, 1 resimden 1.
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • Disconnect the antenna cables from the Mini-Card(s).
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M11xR2 Display Assembly Replacement, Removing Mimi Card: adım 2, 1 resimden 1.
      • The routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M11xR2 Display Assembly Replacement, Turning Over The Computer: adım 3, 1 resimden 1.
      • Turn the computer over and open the display as far as possible.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware M11xR2 Display Assembly Replacement, Pulling The Pull-Tab: adım 4, 1 resimden 1.
      • Pull the pull-tab to disconnect the display cable from the connector on the system board.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware M11xR2 Display Assembly Replacement, Removing Screws: adım 5, 1 resimden 1.
      • Remove the four screws that secure the display assembly to the computer base.
      FixBot'a Sor
      Yorum Ekle
    6. Alienware M11xR2 Display Assembly Replacement, Removing Mini-Card cable: adım 6, 1 resimden 1.
      • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
      FixBot'a Sor
      Yorum Ekle
    7. Alienware M11xR2 Display Assembly Replacement, Lifting Display Assembly: adım 7, 1 resimden 1.
      • Lift the display assembly off the computer.
      FixBot'a Sor
      Yorum Ekle
    8. Alienware M11xR2 Display Assembly Replacement, Sliding New Cables: adım 8, 1 resimden 1.
      • Slide the antenna cables in through the slot on the computer base.
      FixBot'a Sor
      Yorum Ekle
    9. Alienware M11xR2 Display Assembly Replacement, Securing Screws: adım 9, 1 resimden 1.
      • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
      FixBot'a Sor
      Yorum Ekle
    10. Alienware M11xR2 Display Assembly Replacement, Connecting New Display Cable: adım 10, 1 resimden 1.
      • Connect the display cable to the connector on the system board.
      FixBot'a Sor
      Yorum Ekle
    11. Alienware M11xR2 Display Assembly Replacement, Rerouting  The Mini-Card Cable: adım 11, 1 resimden 1.
      • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
      FixBot'a Sor
      Yorum Ekle
    12. Alienware M11xR2 Display Assembly Replacement, Connecting Mini-Card Cables: adım 12, 1 resimden 1.
      • Connect the Mini-Card antenna cables to the Mini-Card(s).
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
darrius
5.213 İtibar
30 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.124 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 1,043
