Ana içeriğe geç
Alienware M14x R2 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Alienware M14x R2 Wi-Fi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14x R2 Wi-Fi Card Replacement: adım 2, 3 resimden 1. Alienware M14x R2 Wi-Fi Card Replacement: adım 2, 3 resimden 2. Alienware M14x R2 Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14x R2 Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14x R2 Wi-Fi Card Replacement: adım 4, 3 resimden 1. Alienware M14x R2 Wi-Fi Card Replacement: adım 4, 3 resimden 2. Alienware M14x R2 Wi-Fi Card Replacement: adım 4, 3 resimden 3.
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: adım 5, 3 resimden 1. Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: adım 5, 3 resimden 2. Alienware M14x R2 Wi-Fi Card Replacement, Wi-Fi card: adım 5, 3 resimden 3.
    • Locate the wi-fi card underneath the battery and unscrew the 3.175 mm size 1 screw.
    • Lift the wi-fi card up and away from the laptop for easier access and handling of the wi-fi card.
  6. Alienware M14x R2 Wi-Fi Card Replacement: adım 6, 2 resimden 1. Alienware M14x R2 Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Lift the gold connectors at the end of each wire up and away from the wi-fi card to detach both antennas, which are the black and white cables, from the wi-fi card.
    • Set aside the now free wi-fi card.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
angel ventura
177 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G4
5 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Fantastic.
I have replaced many things in my Alienware M14x, but am now purchasing a wireless AC/Blutooth adapter from Amazon. Your diagram allowed me to check the new card form factor with the original "Killer Network" one that shipped with my laptop in 2011.
Great pictures and great guide!
Rob MacGregor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 35
Her zaman: 9,837
