Ana içeriğe geç
Alienware M14xR2 Display Assembly Replacement
Neye ihtiyacın var
  1. Alienware M14xR2 Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Display Assembly Replacement: adım 2, 3 resimden 1. Alienware M14xR2 Display Assembly Replacement: adım 2, 3 resimden 2. Alienware M14xR2 Display Assembly Replacement: adım 2, 3 resimden 3.
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Display Assembly Replacement: adım 4, 3 resimden 1. Alienware M14xR2 Display Assembly Replacement: adım 4, 3 resimden 2. Alienware M14xR2 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Display Assembly Replacement, Removing the Mini-Card Antenna Cables: adım 5, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Note the routing of the WirelessHD card (optional) and mini-card antenna cables and remove them from the routing guides on the computer base.
  6. Alienware M14xR2 Display Assembly Replacement, Turn the Computer Over: adım 6, 1 resimden 1.
    • NOTE: The WirelessHD card is optional and may not be present in your computer.
    • Turn the computer over and open the display as far as possible.
  7. Alienware M14xR2 Display Assembly Replacement, Disconnecting the Display Cable: adım 7, 1 resimden 1.
    • Make sure the Center-Control Cover, the Keyboard and the Palm-Rest Assembly are removed.
    • Using the pull-tab, disconnect the display cable from the connector on the system board.
  8. Alienware M14xR2 Display Assembly Replacement, Disconnecting the Logo-Board Cable: adım 8, 1 resimden 1.
    • Disconnect the logo-board cable from the connector on the system board.
  9. Alienware M14xR2 Display Assembly Replacement, Peeling the Display Cable: adım 9, 1 resimden 1.
    • Gently peel the display cable and the logo-board cable from the system board.
  10. Alienware M14xR2 Display Assembly Replacement, Remove the Screws: adım 10, 1 resimden 1.
    • Remove the screws that secure the display assembly to the computer base.
  11. Alienware M14xR2 Display Assembly Replacement, Lifting the Display Assembly: adım 11, 1 resimden 1.
    • Gently slide the WirelessHD (optional) and mini-card antenna cables out through the slot on the computer base.
    • Lift the display assembly off the computer.
  12. Alienware M14xR2 Display Assembly Replacement, Placing the Display Assembly: adım 12, 1 resimden 1.
    • Slide the WirelessHD (optional) and mini-card antenna cables through the slot on the computer base.
    • Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables lie between the display assembly and the computer base.
  13. Alienware M14xR2 Display Assembly Replacement, Connecting the Display Cable: adım 13, 1 resimden 1.
    • Connect the display cable and the logo-board cable to the connectors on the system board.
Sonuç
Terrence15
79.585 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,644
