Giriş
In this guide, we will show you how to remove and replace the Display Assembly.
Neye ihtiyacın var
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Note the routing of the WirelessHD card (optional) and mini-card antenna cables and remove them from the routing guides on the computer base.
Turn the computer over and open the display as far as possible.
Using the pull-tab, disconnect the display cable from the connector on the system board.
Disconnect the logo-board cable from the connector on the system board.
Gently peel the display cable and the logo-board cable from the system board.
Remove the screws that secure the display assembly to the computer base.
Gently slide the WirelessHD (optional) and mini-card antenna cables out through the slot on the computer base.
Lift the display assembly off the computer.
Slide the WirelessHD (optional) and mini-card antenna cables through the slot on the computer base.
Place the NEW display assembly in position and replace the screws that secure the display assembly to the computer base.
Connect the display cable and the logo-board cable to the connectors on the system board.
