Ana içeriğe geç
Alienware M14xR2 Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware M14xR2 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware M14xR2 Hard Drive Replacement: adım 2, 3 resimden 1. Alienware M14xR2 Hard Drive Replacement: adım 2, 3 resimden 2. Alienware M14xR2 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware M14xR2 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware M14xR2 Hard Drive Replacement: adım 4, 3 resimden 1. Alienware M14xR2 Hard Drive Replacement: adım 4, 3 resimden 2. Alienware M14xR2 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware M14xR2 Hard Drive Replacement, Optical Drive: adım 5, 3 resimden 1. Alienware M14xR2 Hard Drive Replacement, Optical Drive: adım 5, 3 resimden 2. Alienware M14xR2 Hard Drive Replacement, Optical Drive: adım 5, 3 resimden 3.
    • Unscrew the four 6.35 mm size 1 screws.
    • Pull up on the end of the orange tab to detach it from the white connector.
    • Lift the optical drive up and out of the laptop and set it aside.
    FixBot'a Sor
    Yorum Ekle
  6. Alienware M14xR2 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Alienware M14xR2 Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
    • The screws are spring loaded and will not come loose from the hard drive assembly.
    • Pull up on the black tab gently as there is still a cable attaching the hard drive to the computer.
    FixBot'a Sor
    Yorum Ekle
  7. Alienware M14xR2 Hard Drive Replacement: adım 7, 2 resimden 1. Alienware M14xR2 Hard Drive Replacement: adım 7, 2 resimden 2.
    • Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
    • Set aside the now disconnected hard drive.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Connor Bovee
569 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-4, Forte Fall 2013 Cal Poly, Team 13-4, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G4
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 11,773
