Ana içeriğe geç
Alienware M15x GPU Replacement
Neye ihtiyacın var
  1. Alienware M15x GPU Replacement, GPU: adım 1, 1 resimden 1.
    • Turn the laptop over so that the bottom is facing upward.
    FixBot'a Sor
    Yorum Ekle
  2. Alienware M15x GPU Replacement: adım 2, 1 resimden 1.
    • Release the battery latch and flip the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Alienware M15x GPU Replacement: adım 3, 2 resimden 1. Alienware M15x GPU Replacement: adım 3, 2 resimden 2.
    • Remove the two 4mm screws using a Phillips #1 screwdriver.
    • Remove the compartment door by sliding it away from the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Alienware M15x GPU Replacement: adım 4, 1 resimden 1.
    • Remove the four 4mm screws with the Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Alienware M15x GPU Replacement: adım 5, 1 resimden 1.
    • Position the laptop vertically so that the hinge is facing up and the laptop is slightly open toward the ground
    • The laptop position should resemble an upside-down V shape.
    • Locate the panel and pry open using a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  6. Alienware M15x GPU Replacement: adım 6, 3 resimden 1. Alienware M15x GPU Replacement: adım 6, 3 resimden 2. Alienware M15x GPU Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Position the laptop normally, with the bottom on the ground and the screen flipped up towards you.
    • Lift the power button panel using the plastic opening tool.
    • Disconnect the ribbon cable by using tweezers to unclip the two small black clips. Remove power button panel.
    FixBot'a Sor
    Yorum Ekle
  7. Alienware M15x GPU Replacement: adım 7, 1 resimden 1.
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Alienware M15x GPU Replacement: adım 8, 2 resimden 1. Alienware M15x GPU Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 4mm screw from the exhaust port cover.
    • Remove the exhaust port cover entirely.
    FixBot'a Sor
    Yorum Ekle
  9. Alienware M15x GPU Replacement: adım 9, 3 resimden 1. Alienware M15x GPU Replacement: adım 9, 3 resimden 2. Alienware M15x GPU Replacement: adım 9, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the two 3mm screws holding the fan in place, then unclip the electrical connection using tweezers.
    FixBot'a Sor
    Yorum Ekle
  10. Alienware M15x GPU Replacement: adım 10, 1 resimden 1.
    • Remove the heat sink by loosening the 4 screws with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  11. Alienware M15x GPU Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Remove the GPU from the laptop.
    • When replacing the GPU, it is important to reapply thermal paste in a small line along the length of the chip.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Tomas Kronmark
193 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G3, Banghart Winter 2018 Cal Poly, Team S11-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G3
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 2,321
