Ana içeriğe geç
Alienware M15x Hard Drive Replacement
Neye ihtiyacın var
  1. Alienware M15x Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x Hard Drive Replacement: adım 2, 3 resimden 1. Alienware M15x Hard Drive Replacement: adım 2, 3 resimden 2. Alienware M15x Hard Drive Replacement: adım 2, 3 resimden 3.
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x Hard Drive Replacement: adım 3, 2 resimden 1. Alienware M15x Hard Drive Replacement: adım 3, 2 resimden 2.
    • Unscrew the four screws indicated
    • Pull on the tab that says "Pull" and remove the Hard Drive
  4. Alienware M15x Hard Drive Replacement: adım 4, 2 resimden 1. Alienware M15x Hard Drive Replacement: adım 4, 2 resimden 2.
    • With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Gabe
8.013 İtibar
3 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
Bir Yorum
Thanks, great guide. Was a bit confused between steps three and four but I simply had to remove the metal casing around the hard drive.
Hasan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 33,041
