Ana içeriğe geç
Alienware M15x Hard-Drive Replacement
Neye ihtiyacın var
    1. Alienware M15x Hard-Drive Replacement, Turn the Computer: adım 1, 1 resimden 1.
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • Turn the computer over.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M15x Hard-Drive Replacement, Sliding the Battery: adım 2, 1 resimden 1.
      • Slide the battery latch to the unlock position as shown.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M15x Hard-Drive Replacement, Removing the Battery Pack: adım 3, 1 resimden 1.
      • After the Battery Pack pops up, remove the Battery Pack.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware M15x Hard-Drive Replacement, Aligning the Battery Pack Tabs: adım 4, 1 resimden 1.
      • Align the battery pack tabs with the slots in the battery bay.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware M15x Hard-Drive Replacement, Pushing the Battery Pack: adım 5, 1 resimden 1.
      • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
      FixBot'a Sor
      Yorum Ekle
    1. Alienware M15x Hard-Drive Replacement, Loosen the Screws: adım 6, 1 resimden 1.
      • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
      • Loosen the four captive screws that secure the hard-drive assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Alienware M15x Hard-Drive Replacement, Lifting the Hard-Drive Assembly: adım 7, 1 resimden 1.
      • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
      FixBot'a Sor
      Yorum Ekle
    3. Alienware M15x Hard-Drive Replacement, Remove the Screws: adım 8, 1 resimden 1.
      • Remove the four screws that secure the hard drive to the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    4. Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: adım 9, 2 resimden 1. Alienware M15x Hard-Drive Replacement, Lifting the Hard Drive: adım 9, 2 resimden 2.
      • Lift the hard drive out of the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    5. Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: adım 10, 2 resimden 1. Alienware M15x Hard-Drive Replacement, Disconnect the Interposer: adım 10, 2 resimden 2.
      • Disconnect the interposer from the hard drive.
      FixBot'a Sor
      Yorum Ekle
    6. Alienware M15x Hard-Drive Replacement, Connecting the Interposer: adım 11, 2 resimden 1. Alienware M15x Hard-Drive Replacement, Connecting the Interposer: adım 11, 2 resimden 2.
      • Connect the interposer to the NEW hard drive.
      FixBot'a Sor
      Yorum Ekle
    7. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: adım 12, 2 resimden 1. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive in the Bracket: adım 12, 2 resimden 2.
      • Place the hard drive in the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    8. Alienware M15x Hard-Drive Replacement, Replace the Four Screws: adım 13, 1 resimden 1.
      • Replace the four screws that secure the hard drive to the hard-drive bracket.
      FixBot'a Sor
      Yorum Ekle
    9. Alienware M15x Hard-Drive Replacement, Placing the Hard-Drive Assembly: adım 14, 1 resimden 1.
      • Place the hard-drive assembly in the hard-drive bay.
      FixBot'a Sor
      Yorum Ekle
    10. Alienware M15x Hard-Drive Replacement, Aligning and Tightening the Screws: adım 15, 1 resimden 1.
      • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Terrence15
80.131 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.277 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 962
