Ana içeriğe geç
Alienware M15x RAM Replacement
Neye ihtiyacın var
  1. Alienware M15x RAM Replacement, Battery: adım 1, 3 resimden 1. Alienware M15x RAM Replacement, Battery: adım 1, 3 resimden 2. Alienware M15x RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Alienware M15x RAM Replacement, Compartment Door: adım 2, 2 resimden 1. Alienware M15x RAM Replacement, Compartment Door: adım 2, 2 resimden 2.
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  3. Alienware M15x RAM Replacement: adım 3, 3 resimden 1. Alienware M15x RAM Replacement: adım 3, 3 resimden 2. Alienware M15x RAM Replacement: adım 3, 3 resimden 3.
    • Slide the compartment door towards the front of the computer and lift.
  4. Alienware M15x RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Remove the two indicated screws for the RAM cover.
  5. Alienware M15x RAM Replacement: adım 5, 1 resimden 1.
    • Push the two retaining clips on either side of the ram outwards, allowing the RAM chip to pop up.
  6. Alienware M15x RAM Replacement: adım 6, 1 resimden 1.
    • Pull it straight out of its pocket.
  7. Alienware M15x RAM Replacement: adım 7, 1 resimden 1.
    • Repeat the same process if there are additional RAM chips.
Sonuç
Aria Saberi
121 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G3, Banghart Winter 2018 Cal Poly, Team S11-G3, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S11G3
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 565
