Ana içeriğe geç
Alienware M15x RAM Replacement
Neye ihtiyacın var
  1. Alienware M15x RAM Replacement, RAM: adım 1, 1 resimden 1.
    • First, take off the battery by moving the latch to the left and pulling it up.
  2. Alienware M15x RAM Replacement: adım 2, 3 resimden 1. Alienware M15x RAM Replacement: adım 2, 3 resimden 2. Alienware M15x RAM Replacement: adım 2, 3 resimden 3.
    • Then unscrew the two Phillips screws.
    • Pull the cover down, then up, revealing the internals
  3. Alienware M15x RAM Replacement: adım 3, 1 resimden 1.
    • Unscrew the two screws indicated
  4. Alienware M15x RAM Replacement: adım 4, 2 resimden 1. Alienware M15x RAM Replacement: adım 4, 2 resimden 2.
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Gabe
8.013 İtibar
3 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.541 adet Kılavuz yazıldı
Bir Yorum
I saw somewhere that it actually takes DDR2 ram not DDR3....
John Moreau - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 16
Her zaman: 24,248
